Camshaft input from experience.
Raider L
Shreveport, LA
William
@jasonconaway,
I have a Lunadi in my trucks 350 very close to the Voodoo. You'll like it, it has excellent across the band power and it has a bit of a lope. It's a good general use performance cam and the 1800 to 6200 rpm is perfect. You won't need big heads, that will save you money but do use a good flowing head just not race heads. These days people are using the high lift relatively short duration cams and get good horse power/torque band cross at between 5500 and 6500 rpm. It ain't a head snapper like some of the Comp. Cams are and for a good all around hydraulic lift cam I think you'll like it. Put on a good set of headers and if you want put a TCI Saturday Night Special 2000 stall torque converter or one up to 2500 in your trans and you'll have a lot of fun!!
jasonconaway
NC
Jason
@jasonconaway,
Thanks for the reply!
jasonconaway
NC
Jason
I’ve spoken with Howard’s again and I’m going with their Rattler cam. I may a sacrifice a little power to get that sound I’m after. But for what I’ve heard and read it’s a pretty sweet cam overall. Thanks for everyone’s input.
cstew47
colombia
craig
Sounds like a good combo. I'd bet you've had at least a few guys ask why you're not running a 750!
I haven't been questioned about it, but, I've seen too many guys over carburete their mills. I'll never hit 5,000 and a 600cfm really caiculates well for torque.
cstew47
colombia
craig
I've installed about a dozen of these in engine build-ups almost identical to yours and never had a complaint. Has the idle you are looking for, but more importantly, is a great performer with 650 CFM carb, ignition and headers.
Summit Racing® Camshafts
Camshaft, Hydraulic Flat Tappet, Advertised Duration 274/274, Lift .450/.450, Chevy, Small Block. see link for specs and detail. https://www.summitracing.com/parts/sum-1785
Hope that helps,
illmanners
That's pretty close to my cam spec. I have a little lope but I can pull stumps out.
burnt
