Catbox
- Jul 12, 2018
- Just Outside of Portland Oregon
- Peter
- C20 Silverado Camper Special
When I do quench, I look for any number between 0.040 and 0.060.
That range has proven to be just fine for an every day engine.
Since you are putting this into a heavy K20, you may want to rethink the overall package.
Torque is what you are after, not top end power.
A super flat torque curve will make you way happier.
Put the largest part of your budget to the heads that will best suit your need.
If that means you have to run a stock crank instead of the stroker, so be it.
With bitchin heads you will be able to make up for it in drivability.
A high compression engine like what I am seeing will not like being lugged around off road.
It will want to rev and breathe.
Build for torque and enjoy an engine that pushes you back into the seat when you punch it.
