1994 S10 1Ton SAS
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
NO NO NO NO!
@bucket
I remember now why i have to remachine stuff..
That clocking ring is already drilled for a 5 bolt adapter.
I wouldve had to have made a whole new clocking ring if i used the 6 bolt adapter.
Vbb199
Salisbury NC
Vince
After measuring about 5 times, i cut the hole in the floor for the shifter, also got the trans and t case in the truck tonight.
Tomorrow ill start working on the driveline.
Vbb199
Salisbury NC
Vince
1 more
NO NO NO NO!
@bucket
There are 6-bolt clocking rings available too. But I fully support the way you did it. I really wish I had those abilities.
Vbb199
Salisbury NC
Vince
Ok, so upon installing my crossmember to get the trans height finalized so i can begin setting up the shifter linkake... of course, i discover the crossmember will interfere with 4x4...
Vbb199
Salisbury NC
Vince
Ill be the first to say, this is some my poorest work ive ever done. I used 1"x.125" tube and looped it under where itll clear the front shaft.....
(Only material i had enough of to do anything with )
Looks terrible, but should work.
I obvioualy test fit it before final weld, fits just fine.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Thats backyard redneck aight!
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Its terrible, but i feel itll never break. I filled every gap then came back with HAWWWTTT passes
Sad to say working in scrap i see alotta fixes like that on once was street cars that get scrapped. Makes ya think of whats bombin down the road nexta ya
Vbb199
Salisbury NC
Vince
Maybe doesnt look so.... dumb? Now lol lol
Still this is the WORST work ive done.
Vbb199
Salisbury NC
Vince
Winch on!
Vbb199
Salisbury NC
Vince
So finally,
1. My insisting on a np241 is validated (lots of available driveline angle)
2. The reason for modifying my cross member
Vbb199
Salisbury NC
Vince
Now that we've depensed with the hillbilly **** of wack ass crossmembers.... i now have 4x4!
Rear shaft also hooked up.
Last thing is to setup 4x4 shifter.
jlyon1006
