1994 S10 1Ton SAS
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
This thread kinda got abandoned.
I'll admit I haven't done a thing besides started pulling the rear axle out.
Front axle is out already.
But I'm in a planning stage.
First up is the front spring hanger I'll make
Someone correct me if I'm wrong, but isn't standard centerpin distance 31.5 or 32 on 1/2 and 3/4 ton?
I need to measure the s10 frame and compare to the axle, worst comes to worst, I'll make my own new pads for it and just weld those on.
Pretty sure it is 31.5".
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Suppose I can check when I get home, but I was pretty sure.
I recall specifically from when I was gonna retrofit a super 60 front axle into a k5 with a 70hd rear end.
Good times.
Sent from my SM-G965U using Tapatalk
Vbb199
Salisbury NC
Vince
Can someone define the difference in a Chevy 8.5" and 8.6" rear end?
I was looking over gearsets on the web for 10 bolts, I'm looking for 4.56's, but I'm finding gear sets for a 8.6" ring gear... Is this a typo?
Or just some generalized terminology for the 8.5"?
Vbb199
Salisbury NC
Vince
8.6 must be a later year 10 bolt axle.
Am I right?
Vbb199
Salisbury NC
Vince
Anyone know of a stout aftermarket axle shaft for the rear end?
Regearing to 4.56, maybe Lincoln rear end.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
If youve got a 10 bolt id use 30 spline axles. I swapped my 78 12 bolt to an 87 10 bolt, i already had 30 spline axles so i bought an aftermarket clutch posi to fit 30, swapped in my axles and switched my backing plates and brakes to stay stock with the truck. Only other change i made was swappin in the posi instead of open gears, i kept the 3.42 ring and pinion from the 87 rear.
Vbb199
Salisbury NC
Vince
I was browsing around on the web, seemed the 30 splines are the way to go.
Vbb199
Salisbury NC
Vince
Front axle stripped, all except right side Knuckle. ..
Time for some turkey
Vbb199
Salisbury NC
Vince
Pic didn't upload
Poppy 87
Bloomingdale GA
R10 Silverado
I believe you are correct sir, I think that the 8.6" is around model year 2000 and later in 1/2 tons
Sent from my XT1254 using Tapatalk
Vbb199
Salisbury NC
Vince
Rear end out!
Time to strip it down, regear, and if needed cut shock and spring pads off to relocate in the old s10!
Vbb199
Salisbury NC
Vince
So, while @bucket was here in Salisbury NC and trading parts with me, he made a suggestion, to use the np208 in the parts suburban I have behind the 4l60e in my s10, to effectively change drop sides, thus eliminating having to cut the tubes and switch drop sides on the 10 bolt... I think it's a great idea. I will look into this, because if that's a realistic possibility, I'm gonna do it.
And of course whatever modifications are needed to make it work (machine work etc) I can do them here.
Maybe while I'm at it, I'll clock it down a little bit since I'm not going to be cutting the axle and kicking the pinion up at the same time...
Yeah, maybe someone here can confirm, that 208 and matching 6-bolt round adapter should bolt right up in place of the S10's 5-bolt round adapter and 231? T-case.
You may just have to deal with dropping the trans crossmember some and maybe clearancing the floor some too.
Vbb199
Salisbury NC
Vince
I have the last transmission that was in the s10 sitting to the side, I'll have to pull the t case from the burb sometime and take that adapter and see if it works.... When the time comes, lll post the results
To add to that, I think it's a np241, and there's the Manual shift variation that's a np233
The adapter you laid hands on is a 4l60e to np233 @bucket
I cannot recall if there is a 4l60e to np241 adapter, but I wanna say there was last time I put a trans in the s10 for the 3rd time
Edit again: 4l60e/233 adapter has provisions on it for the shifter to bolt to.
ExtraZ
