1987 Silverado Help!
AMW
Adrian
R10 Silverado
yeah this truck has the tbi on it i also forgot to mention earlier on but the truck when running does smoke out the exhaust burns oil blue smoke stinks aswell lol
AMW
Adrian
R10 Silverado
not sure the truck has been threw 3 owners the first owner i know had the transmission reabuilt 5 years ago but thats all i know of
violentjay85
pennsylvania
Jason
k-2500
i had a 85 monte carlo with a 305 and it starting running the same way as ur truck i did tons of work to it just to find out it was the torque converter all along
AMW
Adrian
R10 Silverado
well i mean the truck runs good except i cant nail the gas pedal or it will bog out or sputter but it will idle fine it does have a high idle, i notice too when i rev the engine up it slowly revs back down to normal idle
violentjay85
pennsylvania
Jason
k-2500
u got me on this one, its got lots of new parts im gettin a lil stumped...... how about the fuel sending unit inside the tank ? it sounds like a fuel problem.
AMW
Adrian
R10 Silverado
i dont know about a fuel sending unit dont know what that is lol my gas guage does work tho google says the sending unit is with the gas gauge but if it is bad wouldnt my gauge not work?
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
So it burns oil/smokes, it has a high idle, and it sputters at wot. Have you checked compression? Just verify it's not rings or head gasket.
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
The tester is cheap at harbor freight.
AMW
Adrian
R10 Silverado
no i havent checked compression dont have the tool but i can go and pick one up or borrow one what should it be on this truck?
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
I think about 150 for a used motor, but all the cylinders should be within about 10% of each other.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
With the pcv valve not hooked up will will smoke. Adress the vacuum issues first and then see where you are. Vac leaks will cause a lean condition too and make the tbi compensate adding more fuel resulting in high idle but on throttle it will sputter. Fix those lines and pcv valve and then update us.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
If I were you, I would go ahead and pull the Intake manifold, and do all the gaskets from there on up, as well as vacuum lines...That way, you KNOW for sure that all tha bases are covered.
crazy4offroad
Curt
K-10
350/SM465/NP205
Good advice but he has limited experience doing mechanic work. I think he would be in over his head a little.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
If the vac setup is the same on a 350 and 305, and you can give me a couple of days for it to stop raining in the evening, I could snap some pics of my vac lines back there near the distributor. Someone on here knows if they're the same.
Burban90
