1987 Silverado Help!
AMW
Adrian
R10 Silverado
well i got the truck started i hooked a hose to fuel pump and to gas can with gas in it started and ran so now when i get more gas im gonna fill up the tank i cleaned and see if it sucks gas from it hopefully it will i do have the 3 hoses dangling plugged up it still ran so
Guardian
Jeff
c 10
Check your rubber hoses at the top of the tank and also at the tank selector switch. If they split or have holes it will do the same thing.
AMW
Adrian
R10 Silverado
yeah i got to replace those three hoses on top of fuel sending unit but they look fine for now just old cant believe how much these fuel sending units cost i seen 200$ for complete unit on ebay??
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
you dont need the whole thing, unless your fuel level sender is bad.
AMW
Adrian
R10 Silverado
i just have to set my timing now on the truck im gonna try to get the motor at tdc and then take distrubitor cap off see if it is aligned then reconnect and try to set timing
AMW
Adrian
R10 Silverado
BTW does anyone know where the est wire is? on this motor
Jims86
Patterson,Ca
5.7 TBI
Should be up on the firewall, next to the brake booster.
AMW
Adrian
R10 Silverado
ok i fount it then just wanted to check make sure
sam s
