DoubleDingo
- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
It's probably worthwhile to make sure you have sufficient grounds also. The dimming and generally weak electrical stuff seemed to mostly disappear when I ran better grounds between the alternator bracket and the frame as well as frame to battery. I also replaced a broken ground strap from the firewall to the engine block and that fixed the dim cab interior light issue.
Having the charge wire go straight to the battery and also having the second battery running the aux electrical components has really made the entire electrical system function much better.
There are lots of grounds, hefty wires for both power and ground, but the volt meter shows the alternator is lacking. The headlights don't dim, and that is probably because of the relays. Those halogens are good and bright. The charge wire does not go to the battery, though, so that may be the culprit. While the truck is apart, it will get more grounds added and different charge wire routing, and bigger charge wire, since it all has to be rerouted anyhow. The harness is fairly new, ground connections are clean, so it's not old corroded connections.
