10 Bolt Rear Axle Oil Change w/ Factory Limited Slip
Make sure you take off the fill plug first, Just to make sure it isnt seized, other wise you wont be able to put the fluid back in!!!
You can still get fluid back in.
Just get a couple ziplock bags, in the quart size. Fill each bag with lube, then stuff them into the diff housing. Drive the truck. After a few feet, the lube is out of the bags... after a mile or so, the ziplock bags are now "posi additive". Seriously though, the mutilated bags won't hurt a thing.
mike
Numbers on back differential
Can any body tell me what these numbers mean. They are from my 1987 Chevy 1/2 ton 4x4, 350, 5.7 tbi. The numbers are off my rear differential:
GM1, H126, 14055251. These are the only numbers found on it! Thanks for the help.
The Squarebody Reference Library has some info there that might help you, but those #'s don't mean alot. The 14055251 is probably just a part #. I think the H126 is a date code, but that will not tell you anything as far as the carrier of gear ratio. This link should help locate the code you need, then look up the code and unless someone got in it making changes which is usually not the case, then you should know.
http://www.gmsquarebody.com/forum/showthread.php?t=4185
8T6K5
AZ
L98 350 TPI
Thats awesome. Someone should just make pre-filled bags packaged in small boxes. Keep all those plastic jugs out of the trash.....
87ChevyR10
Kansas
NA
NA
NA
What about 5th wheel grease pouches? Those are pre-filled pouches used to grease fifth wheels. They burst once a load is put on them.
radio2000
South Carolina
83 and 88
83 C10 and 88 R10 Burb
I'm planning on changing the rear diff oil in my 89 Burb this weekend. Was going to go with Royal Purple, but someone mentioned Amsoil Severe. Thoughts?
Thanks for all of the info here, need to check the RPO codes on mine, not sure if it's LS....
Sent from my SM-N986U1 using Tapatalk
PC Hot Rods
