WFarm
Central Virginia
K5 Blazer
Last week when I was putting my dash back together I realized I had overlooked that I was missing the short section of expandable ductwork that connects the far right air register to the rest of the ductwork. Apparently it had been removed at some point and never reinstalled. I ordered one from LMC and installed it today.
That's good to know they carry the ducting. Last I knew, nobody did
Drauka99
Northwest Florida, USA
C-10
6.0 LQ4
I got the old u-joints pressed out of the driveshaft, new one purchased for the NV3500 swap. Also got the driveshaft and transmission crossmember cleaned up and painted. Installed the new flywheel and clutch and pressure plate. also replaced the throw-out bearing in the trans. Also zip tied some un-needed wiring out of the way and prepping for putting the tans in place this weekend.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
The TBI injectors and the pod got the spa treatment at my Nephews workshop today. Before
After:
