14bolt FF size vs 10bolt
BryanS
Ft Pierce FL
Bryan
Blazer K5
I’m swapping a 14bolt FF into a k5
Truck has a 4”lift and currently the slip yoke sits out pretty far. Drive shaft looks like it is 2-3 inches too short.
My question is the new diff is bigger. Does that mean the yoke on the diff is maybe 2 or three inches longer and then like magic my drive shaft will be just the right size now?
I’ll need a special joint that would connect to he 1/2 tan shaft to the 3/4 ton axle that I’m assuming someone makes
Yes, the 14BFF yoke is(I think) about 2-3" longer than a 10 bolt one. You will want to check driveline angles also before you bolt everything together.
Zelph
Nevada
NP 208 transfer case?
Weld in new spring perches with the proper pinion angle.
Measure and order a new driveshaft from a vendor of your choice.
BryanS
Ft Pierce FL
Bryan
Blazer K5
Invest in SYE kit.
I think it’s NV261
Zelph
Nevada
What side is your front driveshaft on? Or the front axle differential?
Zelph
Nevada
I’m thinking he has a 208.
If not, we need to figure out what front axle he has.
BryanS
Ft Pierce FL
Bryan
Blazer K5
I may have seen the wrong numbers
Is this the tag I should be looking at?
The front shaft is on the correct (passenger) side
Here are a couple pictures of the case
Thank you guys
The 208 was used from '81 to '88. Then the 241 was used after that. No 261 in these trucks.
Yes, the 14 bolt diff is bigger, but the yoke is rather close to the center section for it's size. Your driveshaft will fit roughly the same after the swap.
The conversion u-jount you need is Precision #447. Unless parts have been swapped around in the past, of course.
Zelph
Nevada
That there is a 208.
I wouldn’t buy any u joints on assumptions. Get a set of calipers and measure what you have and buy accordingly.
We’ve all seen weird and strange things on these trucks that typically get blamed on a po, but the factory did some odd stuff too.
BryanS
Ft Pierce FL
Bryan
Blazer K5
Next question. Not sure if this should be a different thread but it seems all the right people are looking at this one :)
My front axle is 6 lug and I need to change that to 8
It is a 10 bolt.
I’m thinking I can change the hubs and basicly be good to go?
I’ll need to do the ring gear to match the rear but what else do I need? Rotors and calipers or can I reuse what I have?
legopnuematic
Licensed Junk Dealer
MO
Spencer
Rotors will need to be 8 lug rotors, they are a little larger than 1/2 ton 6 lug rotors are.
Calipers should physically interchange but the piston size is different between 1/2 and 3/4 ton calipers.
jjrussell88
