CheemsK1500
- Jun 3, 2022
- Texas
- Paul
- K1500
I noticed the small hinges when I looked at my friends ‘95 WT with its driver door hanging on for dear life. From what I’ve seen, the hinges seem a little undersized for square body doors too, although the sag doesn’t seem nearly as bad as a lot of GMT400s I’ve seen. Not beefing up the hinges for the heavier doors on the GMT400 was one of GM’s more questionable design choices on these trucks. Thankfully they mastered the art of the door hinge by the time the GMT800 was introduced.The doors increased in weight but the hinges are basically like squares, right? so the extra weight and size and larger glass on the same hardware in the same amount of time = sag city? The 1996 i have doesnt have too bad of a drivers door surprisingly, for a silverado trim door.
I won’t pick on GM too much for this though, because I’ve seen many 80-96 Ford doors sag, and a sagging Ford door gives you the added bonus of snapping off interior door handles on a regular basis until you get the latch/striker alignment just right. This applies to both the early die cast handles and the later plastic ones.
