Catbox
- Jul 12, 2018
- Just Outside of Portland Oregon
- Peter
- C20 Silverado Camper Special
We worked on the car on Sunday.
I had her finish cleaning the seats as she totally missed the sides of them.
After that we oiled up the adjuster wheels and pivot points so they moved freely.
Then I confirmed that the neutral safety switch is a pile of crap.
I loosened the mounting bolts and moved it around until the car started cranking again.
So looking around the net seems to turn up few options on the switch.
I will improvise.
I just bought her this little button that will be mounted under the headlight switch.
There is already a hole there where something had been mounted and removed, so it will be perfect.
She will now have a push button NSS while cranking the ignition.
I will simply splice into the wires without disconnecting them, kind of an anti theft thing as the OG switch will still kill the starter.
While on the Billet Automotive Buttons web page, I found this one for my truck.
Max has yet to actually fix my horn, so this will work like a champ in the meantime...
I will improvise.
