Catbox
- Jul 12, 2018
- Just Outside of Portland Oregon
- Peter
- C20 Silverado Camper Special
We got started on the R&R of the cooling system on this thing yesterday.
First I poured in a bottle of cooling system flush and fired it up and let it run for the 20 minutes the bottle says too.
After that I wanted to test out my swap meet Snap On pressure tester and it held pretty well.
I suspect it may have needed a better seal at the connection though...
Here we are putting water into the upper hose to reverse flush it...
And then we used the lower radiator hose to flush it out the other way...
Then we went as far as to run it through the heater hose as well to make sure that is as clean as it gets.
After that, it was dark fast because we started late.
Next though, we are going to reconnect the hoses to old radiator and fill the thing with water.
This little tester is super simple as it just has an adapter that a plastic piece force fits into.
In the bottom of the S, there is a fluid that you fill it with that is blue.
While running, the whole thing sits in the filler neck of the radiator and while the car is running air bubbles through it.
If the fluid changes from blue to green or yellow, there are combustion gasses in the coolant.
Now you need a fresh set of head gaskets and a possible trip to the machine shop.
If the fluid stays blue, you are good to go.
We shall see another day what the test shows us as work is busy and I have low want to perform currently.
So I am dragging my feet all day, that just means I work longer each day to make up for the slackerism I have.
