WTF? Intake manifold crud
Snoots
Roger
Jimmy Sierra
350 w/203
It's okay to feel a little shaky.
Just do yer best. If it leaks anywhere, chalk it up to experience.
If'n it don't,
Ewhitaker0020
Kentucky
Very cool! I appreciate you all. Thanks! I’m so afraid I’m going to start the engine and discover a leak.
This is what I'm worried about. I just had to pull my intake manifold for a second time, because I didn't put enough rtv in the rear gap between the intake the the block and I had oil coming out pretty badly. 2 quarts a day bad.
On the upside, there's no way my driveshaft or underside of my truck will rust now. Plenty of anti-rust oil all over the underside of my truck.
I'm just hoping tonight that when I fill it back up with antifreeze and start her up, it won't leak.
Carlton Huitt
Gilbert Az
Carl
C 10
Were all pulling for you. Your success is our secession.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I've learnt to check that gap between the china wall and bottom of intake. If it's over 1/8" I'll lay a thick bead of Right Stuff and let it set up... like overnight if you can. After it's set I'll build up the sides and top of the bead and then set the intake down on it. Then it's sealed proper and doesn't
leave a big mess, nice and neat.
brentjo
