maxtwms
- Jan 29, 2014
- Alabama
- Max
- K10
Hey guys, my truck bed has been sagging in the passenger rear side so I went to check my Suspension and found the shock on that side was about 1.5" longer. That shock mounts angled towards the cab.
Anyway, while removing the shock I noticed the stud was a little loose and then found that it had been wearing on the thru hole for some time causing it to become a slot.
My question is, should I just mount/weld a 3/16" plate to the inside of the frame and match-drill a new hole, or is there a preferred "standard" way of approaching this?
Ill try to get some pictures this afternoon.
