Hello From NorCal
82_GMC_SIERRA
San Jose, California
Jose
Sierra Classic 2500
Hello everyone,
New square body owner from CA. Just wanted to say hello and get some more info on my truck. This is my first square body.
I’m usually tinkering around with older pre-smog vehicles but ended up with this 1982 GMC Sierra Classic for a good price.
It appears to be solid. Recently installed the new seat and carpet it came with and a spare Retrosound radio I had on the shelf.
Fresh plugs, wire set, cap and rotor. Carb seems fine, just needs Choke adjustment to make sure it turns on easier when cold.
I did swap the dash with LEDs and replaced some gauges. So far everything works minus the heater blower motor which is next on my list with the cold weather coming in.
Swapped in a new master cylinder since it was leaking and will work on the front calipers next. Replaced door and window seals. Will need a new windshield in the future.
After decoding the VIN , it appears that I have a 3/4 ton truck.
HD brakes most likely since it’s has a G on the vin for 8001-9000 GVW / Hydraulic brake system designation.
I did notice that the engine has a smog air pump and the air injection system but After crawling under the truck to bleed the brakes, I noticed it had no Catalytic converter. Just a Y pipe and single exhaust.
Could this be one of the non-Cat CA trucks?
I replaced all the vac hoses on the engine in preparing for the Smog test to finalize my registration. Any chance anyone else has this? I’m hoping it’s a non Cat truck, would make passing easier. It runs really well after the tune up and is super quiet and smooth.
Here’s a picture of my VIN
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. I could be as it's a 3/4 ton truck. I checked the vin and got 8 records for smog checks.
Is the emissions sticker gone?
https://www.bar.ca.gov/inspection
82_GMC_SIERRA
Jose
Sierra Classic 2500
I honestly did not check. I’ll take a look tomorrow. Is it the one on the Air cleaner?
I noticed it had a diagram for the hose routing.
Or would it be elsewhere? I know I’m missing the glovebox one with RPO codes.
Thanks for the check! Didn’t realize it can be looked up like that
animal
Lee
c10 silverado
350ish
:welcome:
ali_c20
Austria
Alexander
C20, K5
Yes the sticker on the air cleaner or on top of the radiator support. If it is a truck with catalytic converter the word CATALYST is very prominent on the decal. Or NON CATALYST.
ssxa
