Will these work for LED Dash Lights?
87silveradok20
Ohio
Levi
Silverado k20
Those look the same as what I used and they work great
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
I used led strip lights instead of individual that replace the incandescent. The wiring was much simpler and the gauges are well lit without any dark areas.....just another option.
quadracerx
Graham, WA. USA
Steve
One other question....
How many will I need to replace all of them in the guage cluster?
Thanks,
Steve
SDJunkMan
Black Hills of South Dakota
Jeff
I think there are 12 in the gauge cluster of my 78, plus one in the wiper switch.
350 w/203
Just remember they won't dim properly unless you add a PCM circuit to the dash light output.
quadracerx
Graham, WA. USA
Steve
Ok... So how do I add a PCM circuit... IF I dont does it means they run full bright all the time?
Thanks..
Steve
87silveradok20
Ohio
Levi
Silverado k20
Thanks,
Steve
I used like 6 I think for my gauge cluster and the heat controls.
350 w/203
Thanks..
Steve
Check this out first:
https://www.digikey.com/en/articles...dim-an-led-without-compromising-light-quality
This is good:
And this:
https://www.amazon.com/Auto-Meter-9114-Lighting-Dimmer/product-reviews/B000N8GIYG
Or this:
https://www.amazon.com/Dimming-Controller-Adjustable-Brightness-Zitrades/dp/B007V1B0W8
I used the term PCM (Pulsed Code Modulation) incorrectly. I should have use PWM (Pulse Width Modulation).
Use a unit that can handle at least 25% more amp draw than what your LED's are rated. That'll give you a safety margin from overheating and increase the longevity of your unit and LED's.
Just Google 'LED Dimmer for 12V Automotive lights' or similar and you should be able to find something that suits you.
jlyon1006
