What is you headlight setup
dapperben
Las Vegas
Ben
We just did a Dapper Lighting FourSix BiLED kit on our shop truck. They came out awesome.
dapperben
Las Vegas
Ben
@dapperben dang that looks fresh as hell!
Thank you sir! We're seeing a ton of squarebody owners coming to us so I figured we'd hop on the forums and see what the lighting scene was like. If you guys have recommendations or suggestions for parts (lighting, billet, carbon), feel free to voice them out. We're looking to expand our selection to you guys!
Doppleganger
OH-MI: Just like it sounds
I've got the Hella e-code lamps to install - they use the H4 and H1 bulbs. Have heard of some using HIDs or LEDs in them, but no idea how well they work.
Cibie was the very best for pattern and light, but they are long gone now.
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
I used these, little roundy round with the company with wrong parts. but overall happy with the improved light, difficult to aim. Low beams shown, huge difference! High beams later replaced as well
I almost bought from them till I seen all The current BBB complaints. Good thing you got what you paid for :happy160:
GMC_Nick
pittsburgh
Nick
350 sbc
Relays hooked up to some sealed beams and led 1157s in a factory housing 81-82 bumper hooked also on a relay and to a switch. Super bright but not overly bright and can see great. I do lots of night driving and have no issues seeing ahead even during rain.
Disco
Texarkana, TX
Big 10
I have the 9003 sealed-beam replacements as well - the type with the crystal-clear lens (no fluting) and the facetted reflector, but I have not installed them yet.
I honestly have not gotten to drive the truck yet. Soon, hopefully. I have driven enough older vehicles with sealed-beam lights, however, to know that those bulbs are absolute $#!+... Especially with old wiring causing electrical resistance and making the already dim bulbs dimmer.
Sorry, @DoubleDingo, but I will be using the obnoxious LED plug-and-play 9003 bulbs.
My part of Texas thinks streetlights and sidewalks are of the Devil. I'd rather irritate another driver for a few seconds than hit a pedestrian walking on the side of the street.
The bulbs I use are only 10k lumens (about 5000 apiece) though - less than many new cars with factory LED or HID lights - and I actually take the time to properly aim my lights to minimize dazzling. While 10k lumen is about 5x brighter than halogen bulbs, it's more the pure white 5000K color I'm after than anything. The warm 3000K of halogen bulbs absolutely disappear in heavy rain to the point that I might as well not have my headlights on at all. Not a good place to be in poor weather. The bright blue 8000K+ bulbs are equally as bad, and in my opinion, because they are BLUE, they should be an impoundable level of illegal. However, light color in the 5000-6500K range is the perfect color to cut through the rain and light up road signs and reflectors down-range.
Carb'ed Vortec 350
I'm not the only one that dislikes LEDS. I hate them because of being temporarily blinded. Although, improved lighting is a must nowadays in our older rigs, because the new cars have blinding lights from the factory, and the LED streetlights not being as good as the HPS lights they replaced make the streets darker and unsafe.
Disco
Texarkana, TX
Big 10
I dunno. A proper LED headlight setup should not dazzle. LEDs that use the same light pattern as halogens and that are aimed correctly should not have much more effect on opposing travel than halogens. Most of the issues with LED lights are units aimed too far up or too far into traffic, or they are units that don’t have the correct light pattern to use on-road, like the sealed beam replacements that are just a field of LEDs. Or they’re those stupid LED light bars…
The bulbs that replace non sealed beam bulbs and use high powered CREE LEDs placed in the same spot as the halogen filament should produce a very similar light pattern, which should limit dazzling.
As far as LED streetlights go, I personally find them easier on the eyes and better at illuminating the road, especially in poor weather, than the outgoing HPS bulbs.
And I know you aren’t the only person who dislikes them. I just saw that you said something about it, so I mentioned you.
timbritton
canada
Tim
1500sierra
My 82 has a setup I made . 2 new relays one for hi one for low . Took the feed from the floor switch to the low relay the other one to the high next I took a new fused battery feed for each hi and low. Hooked one feed to each. I ran new wire to both lows and both hi’s from the respective relay. I also made new ground wires for each bulb and to a good ground. My lights are fabulous now.
Johnny Atomic
Little Rock AR
Johnny
Sierra Classic 1500
Very happy with these headlight housings:
And H4/9003 LED Headlight Bulb from Amazon. Bright and clear, and pull less current that stock or halogen bulbs.
I also had to buy a pair of these:
https://www.amazon.com/gp/product/B01N5HLF7U/
So I could reverse the wires for High beam and Low beam. If you plug them in straight out of the box the you'll get only low beam on high setting, and get all 4 high beam on low setting. You could also use this to have all four lights do both high and low beam. But I went with the tradition style with 2 lights for low and all 4 for high beams.
Top lights new LED, bottom original lights. BIG DIFFERENCE
Price for all the stuff from amazon was about $100 to $120.
Buicknut
Cincinnati Ohio
Joe
V1500
I run hella buckets.
Led's for low beams) and halogens for high beams.
And some led driving lights down low. Very happy with this setup. Had to keep some halogens to melt any snow or ice that can build up in the winter. Also used the lmc headlight harness and wired so all 4 stay on when high beams are on.
I spent alot of time aiming these to not blind oncoming traffic
@R Carnella where did you get the Hella buckets from? And do you know the part numbers?
rjshope2007
