Carb'ed Vortec 350
Rusty is still tag-able, his user name just has a space in it. I would have just tagged him to show it, but I figured I wouldn't bring his attention to here if it wasn't necessary.
ODD! When I tried tagging him earlier his name didn't show as an option. I did the @, then typed in rusty and waited for options, and his was not one of them. Just now I tried it the same as I did earlier and it showed up. Only difference was computer(earlier), phone(now).
Good to see he didn't deactivate and erase everything, he's a good guy and brings a twist to a situation.
RattleSnack
Ford City, PA
Bill
D30 M1028 CUCV
6.2 Diesel
Getting the CUCV ready to bring out of winter hibernation...
I had my dash apart to replace the CUCV voltmeter with 24v & 12V voltmeters from VDO, and to replace the heater controls with a new one from LMC since the old one looked pretty ratty. While everything was apart, I cleaned all of the contacts on the cluster circuit board, and I added LED's from NAPA for the gauge lighting and voltmeters. I thought it turned out pretty well.
Next, I installed new alternator pulleys so I can use 1/2" wide FleetRunner V-belts instead of the factory 3/8" belts. Everyone who's owned a 6.2 CUCV with dual alternators know how the belts are prone to wearing out and squealing all the time. So far, so good. They seem to be nice and quiet. The real test will be when I put some miles on them this summer.
Curiosity got the better of me so I tore apart the TH350 to see what the issue was. Guess this isnt supposed to look like this lol. Off to the scrap yard it goes :anitoof:
No sir! That's impressive looking and deserves to be cleaned up and used as a combination paperweight/conversation-starter!
mxer147
Colorado
Jack
k20
Stupid as this reads, sprayed two coats under moonlight and then got up at dawn to tack cloth and spray last coat….definitely not gonna win truck show competition….but perfect enough for me.
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Saturday projects continue - installing the driver side shaved panel/ getting prepped for the outer roof skin replacement
Blazerlady
MI
Andrea
K5 Blazer
5.3 converted
Ball joint and axle u joint replacement in my 1985 Blazer, was not driving and steering right. One side,the ball joints were ready to come apart and were froze up on the other side. The u joints, seen startings of rust coming out. Drives and steers a whole lot better now.
fofiddyfo
wisco
R3500
FINALLY got the (hopefully!!) last leaky fuel line replaced. Today is the first day she’s moved under her own power in well over 5 YEARS!!!! She ran and drove better than I could have even hoped; so well that I think I’m gonna finally put the bed back on and register her so I can DRIVE HER this year!!!
Phillippio
Tucson
Greg
C15
I have been busy on the old truck.
-New brakes all around
-New front suspension
-New tires and shocks
-New door and wind window seals (wow, that was not fun)
-New door cards and stuff (armrest are on back order)
-New carb and air cleaner
-New hoses and belts
-New dash bezel and lens with gear indicator
-New dome light
-New seat belts
-New led front fender marker/blinker lights
-Lots of little tinkering stuff as well.
I just found a leaking freeze plug so guess what is next.
Drove it to lunch yesterday and it was fine. Got in it to go home last night and the gauges were flashing "18V" and "Check engine". Pulled it back in the shop, hooked up the multimeter and sure enough, it was sending 19+ volts into the battery. Shut if off and unhooked the battery, I'll go get an alternator at lunch today
Richey92
