JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
I had to create collages with those photos to get them to load on here. They were sent to me from an I Phone and I have an Android. Apologies for the quality, I wish I could put the pictures directly in.
ChuckN
Bellinham, WA
Chad
I get the idea. Either way, that TBI looks much better!
Tonimus
Phoenix
Tony
C10 Suburban
Any chance you have a thread or link on how to modify exactly?
A couple of pics of what I did. Hope it helps.
mxer147
Colorado
Jack
k20
Lightly sanded the hood epoxy primer, thin layer of filler, then sanded that mostly smooth. While I was waiting for the filler to harden, I removed some of the heater distribution vents to determine what’s missing and needs repair. The box itself is a little loose so gonna have to tighten the blind nuts on the firewall, missing the left vent tube, missing seals, and looks like PO trimmed a little too much on one vent, and used 200 mph tape rather than repair it properly. Probably gonna take an hour or two to make it right.
Johnny Atomic
Little Rock AR
Johnny
Sierra Classic 1500
Painted my mirror covers and some stake pocket covers from Truxedo. Spray can basecoat from AutomotiveTouchup.com, and SprayMax 2K clear from Amazon. Also cleaned up and clear coated my unobtainium 1983 GMC grill.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Okay,... Start sharing your magic or stop shaming us mere mortals.
Your call.
WFarm
Central Virginia
K5 Blazer
Battery was starting to struggle a bit and tester said it was at 60% CCA rating so got a new battery from Summit and dropped it in. I had an Odyssey battery in my 87 square and had the recommended battery tender for it so got another one. The old battery will be used in the horse trailer until it completely dies.
Also got some new, clean floor mats!
ChuckN
Bellinham, WA
Chad
I’ve always wanted a set of the GM floor mats. They take me back to my youth, but the cost of entry always made be balk.
I’ll end up with a set eventually.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Cut off 3/4" off the 1/4-20 all thread because it was too long and got rid of all the washers except for one on the air filter lid. Also turned it so the grooves are vertical. ;)
MUCH better!
Johnny Atomic
Little Rock AR
Johnny
Sierra Classic 1500
i really like those mats
Johnny Atomic
Little Rock AR
Johnny
Sierra Classic 1500
Your call.
no magic. i didn’t tell you it took 4 times painting them. Waiting two weeks before putting them on. Then they still weren’t fully cured and then yesterday this happened from the tonneau cover. Stripped them all the way down,now using an adhesion promoter, and repainting again today.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
Looks great! Did this air cleaner top have a drilled through hole? I have one we found at a swap meet decades ago that has a threaded hole for the carb stud. Of course you still have to trim the stud to fit....
blue900
