On the truck or off, 3rd / 4th photos are definitely widowmakers
yes, im just saying im glad it doesnt seem to have them on his because 1) that would mean finding new wheels 2) scary
The 2nd photo,.. i think may be one, without the ring, but it might be a normal one and i just have bad eyes
ChuckN
Bellinham, WA
Chad
@JamesSam when I bought The Truck the tanks had already been replaced. The PO told me they re-used the fuel pumps.
Initially I felt that the RH tank must have a weaker pump than the LH tank but as time has passed I can tell no difference. You could have a switching valve issue, I am assuming you have not tried switching tanks to see if the truck runs better on one pump than the other.
I don't think dropping the tank is that bad of a job. Of course I have some jacks and things to help me.
Would a transmission jack help with something like that if a guy was tackling the job by himself?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Unless the tank is full it's not necessary. Would be helpful though, especially when bolting it back in. Would help when messing with the hoses too. But a regular jack would work as well, just to hold it.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Unfortunately I just filled the working passenger side tank to help with all the problem solving I was sure related to TBI electronics that live in and around the throttle body itself. Now it definitely seems as if it could be the old electronic pumps in the tank and/or clogged sock filters on the inlets to fuel lines. :rolleyes:
Ajax19
Socal
Ajax
Started welding up the braces ended up using flux core since it's to dam windy not my prettiest but I did a few passes at least I don't have to look at them under the deck got dark on me and was having a hard time seeing even with a light maybe I'll grind em down and do a gas pass on them tomorrow lol
Got the last piece of the rear bracing tacked into place, after freezing my butt off I called it quitting ting to go warm up. I figure a little progress is better than no progress.
78C10BigTen
pennsylvannia
C10 BIG TEN
Out in the garage. Found a whole bunch of surface rust under the door frame weatherstripping. Went after it with my corner sander, and the drill with a plethora of different wire wheels, then applied some Eastwood Rust Encapsulator. I’ll eventually get her painted but this will save on ‘er for the meantime.
I like your wheels.
Ajax19
Socal
Ajax
Ended up putting the trailer brake controller next to the tank selector valve there was already a hole there so I only had to add one new hole to the already swiss cheese dash I don't think I have ever had another vehicle with this much spaghetti lol one day I'll have to tackle this for now were just gonna pretend it's not there lmao
Tdwmaxwell
