incubus2432
Grafton, Ohio
Shekkie
Now that the bedliner is in and (mostly) cured I bolted in my new tiedowns
That’s water pooled/spotted in the pics. Monstaliner recommends misting the surface after initial setup to help the curing process.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Washer fluid reservoir leaking again. I had to try this. The stock pump isn't strong enough to pull fluid with this setup.
I'll probably go with a 2 liter aluminum tank from Amazon for $30 and a different pump.
Then again, might just upgrade the pump and let it fly.
I'd go with this one because your pump will fit right on the side and work great. I have this one and just put a new pump in and it works great.
Those look great, where'd ya get them? I've got large D-rings on my rear posts but want to add something smaller/slimmer up front and possibly on the floor like that as well
SierraClassique
Michael
5.0L V8
the vanity projects continue!
I touched up all the badges / emblems on the Jimmy with Testors enamel paint.
The grill and headlight bezels have new life with some coats of Krylon Dark Metallic spray paint- I know there is a lot of argent silver debate on GMSB but I wanted to go with something darker.
Lastly, fifty shades of beige has come to an end. The a-pillar, b-pillar, and connecting interior panels are now ‘smokey beige.’
To balance cosmetic vs. functional projects, I changed the fluid in the transfer case and gear oil in the diffs for the first time since I acquired the Jimmy a year ago- no metal shavings but very overdue!
Carb'ed Vortec 350
I like it!
Camar068
10 yrs Air Force
1lejohn
texas
john
k-1500, 2500 HD
Is that a swing out step on the front or one mounted in a receiver hitch? Its a cool idea either way.
Magna86
VA Beach
Magna86
Chevy 350
Rebuilt my upper and lower control arms........... spend the money and get the tubulars.
I will if there's a next time.
No budget for tubular control arms on this truck and for as much as I drive this one not needed. It will be a big improvement replacing original worn suspension and gearbox upgrade to quick ratio.
SierraClassique
Michael
5.0L V8
It’s a hitch mounted bumper step from Harbor Freight - it’s great to get into the engine bay of a lifted rig! Only con is having to reverse with a tow rope to get it out haha, but can’t really complain for $28.
1lejohn
texas
john
k-1500, 2500 HD
Thanks. Installing a front hitch is on my project list. I have one of those steps that go over the tire. The hood gets in the way using it. I usually use a portable work platform, it's much better than a step ladder. The bumper step is perfect for when you are on the road.
SierraClassique
Michael
5.0L V8
Nice! This front hitch receiver ($238) went on my ‘84 Jimmy pretty easily. I have 4wd so didn’t need a front hitch to put a boat in the lake or anything, but I wanted to put it on nonetheless.
Unfortunately, I do not have OEM tow hooks (and do not want to pay the small fortune they’re selling for online), but I would be curious how they play with the hitch receiver. As an aside, I bought a few of these Harbor Freight tow hooks, which are oriented 90° differently than the OEM hooks, so trying to do something with these may be a creative undertaking sometime soon. All advice / suggestions from the community is welcome!
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
It seems like almost every boatyard around here has a truck with a front hitch. It sure makes jockeying the trailers around a lot easier.
k-5Ed
