DrvnDrvr
Central Oregon
Al
When I put on the fuel regulator it leaned out the engine causing it to run hotter and boil the fuel out the filter. One thing leads to another. The phenolic gasket fixed the fuel boiling problem but the damage was already done. Cheap fix.
nvrenuf
Mobile, Al.
I finally wrapped up a few loose ends (nothing exotic) and pulled the Blazer out for a bath and drove it some.
New bracket for my p/s fluid reservoir
Mounted a few more things in the cargo area, I now have a tool box, storage box (straps, shackles, etc), ice chest, CO2 tank and water jug.
Just pics of it outside for the first time in MONTHS
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I don't understand what the issue is. You need a starter for a car with a 153 tooth flywheel. It's not uncommon, I have about 5 of them in my garage. Looking up a truck starter will get you nowhere. This was all mentioned in your thread about the truck. I'm honestly surprised that your mechanic doesn't know that either. Far as I know, a BB Chevelle starter will not work either because they all had a 168 tooth flywheel.
Just get a starter for an '84 Caprice with a 305. It should be a straight bolt pattern and will work on your engine.
I went back to find that post but couldn't. Either way I sent him a text about it. I would've definitely tried that if I had seen the post but I guess I missed it. Thanks
GMC_Nick
pittsburgh
Nick
350 sbc
Hey guys here's an update on those door cupholders and speaker pods I bought. These are just roughed in as a finish, I plan to paint them the right color and sand again I just wanted to see them on the truck. I am going to flip the sides I put the cupholders on so the round part is in the front, and also move the speaker pod forward more. All and all they are pretty nice if you aren't a stickler for everything being all original. I don't like doing anything that is irreversible like cutting holes in doors or trimming panels so these are my style. Will update again when they are finished properly and where I want them.
gmbellew
Kansas city
glen
suburban 1500
Seems like it would be hard to get a drink in an out with the cup holder up front?
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Rad!!
Those look like handy cup holders and storage trays. One benefit to switching them around is the cup holder will be closer to the door's hinge point and you can carefully close the door without spilling a smaller drink such as a 12/16oz can. I still wouldn't do it with a big gulp cup though, lol.
82sbshortbed
Fuckemall!!
SE Texas
Doug
oplinger
Nashville, TN
Justin
r10
These look RAD!! I think putting the cup holder in front of the storage space is a great idea. would be easier to get the cup in and out without risking hitting the seat or your leg. Great idea though!!
justhorns
Denver
Lee
So, I fixed a rattle in my dash. The brake release bracket became loose where it bolts in immediately behind the dash. Rattle gone. I then screwed around with my hood, which was up on one side, and could be pushed down. I tried raising the rubber stop, which did not help. Lowering the latch assembly in the middle pulled down the hood and it now fits tight. Not perfect alignment, but much better. I think I may need to play with the fender alignment next, if I care. Its the little things. I cannot believe how much quieter this 43 year old truck is than when I got it 3-4 years ago. vent window latches, dynamat stuff, fixing rattles and lubing door hinges. All of this helps
2manysquares2care
