78C10BigTen
pennsylvannia
C10 BIG TEN
No, it’s not that dark. Probably 20-30%.
Better pic of it.
Looks GREAT!!! I like dark windows!
Wich btw thats what ive done to my mini "square" lately, a free tool box, idk if i like it
HOTFOOT
northwest ct
michael
gmc k3500 srw
looks like a weather guard very well made! I have one I bought years ago and I can still close it from one side , very tuff top
78C10BigTen
pennsylvannia
C10 BIG TEN
It is a weather guard. Its missin a bolt in the latch and it dont like to open once latched. But it was free. Thing i dont like is its shallow, cant fit a gallon jug standin up...
Flatwater
Nebraska Panhandle
Pulled the interior apart to clean. Prior owner was a bit of a pack rat. Kinda gross… Parts pickup we dragged home had a green bench in it. Looks a lot better.
Camar068
10 yrs Air Force
Got the bed off today to swap the sides. Had to grind/cut 3 bolts out....and punch them out the supports underneath. Really thinking about putting torx head bolts in when I put it back on. While it's off I'll replace the rear shocks, fix the parking brake, and take care of some surface rust.
Anyway, it's off to the welder to do the cab corner tomorrow. Hopefully have it back next weekend with everything fixed underneath.
wlwarnke
Helotes, TX
William
Added a 2nd battery.
Went back a few days later and swapped out the junction block on the firewall with a proper terminal block. Now I only have 1 battery cable going down to the starter.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
FINALLY got my Cold Case radiator. Started the install and ran into a couple problems: need all 4 rubber mounts, all worn down down and gives radiator play. Lower rad hose port is bigger on the new one. Pretty much it. Other than that, radiator is dead on
cph60fixr
