gmbellew
Kansas city
glen
suburban 1500
For that style, I think @gmbellew is correct.
Not sure on the stacked style.
I am basing that on memory of my 91, thinking the same thing- WTF aren't all 4 on ?
:flame:
correct, 89-91 style have only either high or low. i have a 1990 suburban, and that is how it is with the factory harness. i think they cheapened the harness and the wiring cannot support all 4 firing at once.
the stacked headlight grille that preceded his style had lows and highs light up for high beam. that was how my old 84 blazer was.
hoagster
California
K10, 1500
5.3l
Installed part of the AC mount and worked on installing new power steer hoses and relocating some wiring for the AC before I can't get to it!
silverscottsk10
trafalgar indiana
mike
Started the tear down of the 454, timing chain may be a little worn, so far not much carbon build up at all, nothing in the oil I can see, removed the 40 pound cast intake, not looking forward to moving the heads, together probably weigh as much at me
Sent from my SM-N950U using Tapatalk
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Ok, day 2 of carb swap from ****** eddy to reliable never fail ya Quadrajet. Lol
Day 1 in my build thread. Anyway I went and got some longer bolts and cap screws because they aren't engaging enough threads for me. And the front right was loose and stripped for me.
So I chased the threads with a 5/16-18 tap. As you know aluminum is easy to tap with just a little WD40 to help it along.
What I traded longer bolts for.
Difference between the two
Mounted with new hardware. It worked really well. As I was able to tighten the newly tapped holes with the longer screws and bolts.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Then I took my hard fuel rubbing from my 305 and cut it to work on the BBC.
Then got the MF mounted and fuel line connected. But, it's getting dark so I'm done for tonite.
Not too bad for a redneck. Lol
Stay tuned for more this weekend
jjester6000
Illinois
Jack
C1500
Getting O'l Yeller ready for paint.
I'm doing a 2 tone (maybe woodgrain to match the doors) so I just picked up some chrome trim from the junkyard.
(It should hopefully throw off all the ****** body work)
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Oil change time. PF1218 filter at Deadvanced - $ 8.49.
5 quarts of Castrol 20W50 ( did not see it at Advance) $ 16.97 at Wally World.
They do not have many AC Delco filters, so you gotta bounce around.
5 quarts Supertech 10W40 for top offs :p
$ 12.96.
Actually seeing some hot young chicks = priceless.
:chicken:
$ 12.96.
:chicken:
As in baby chicks under the heat lamps?
Lol
Bought and assembled an engine stand for her new heart and stripped the harness, manifolds and trans off of it. Tear down will continue tomorrow
Sent from my iPhone using Tapatalk Pro
82sbshortbed
Fuckemall!!
SE Texas
Doug
After yard work I fabbed the throttle cable holder to it with my dremel. A lot less of a s in the cable between holder and firewall and is much smoother than before.
Only things left are change plugs and plug in booster hose to back of carb and fire it up.
78C10BigTen
pennsylvannia
C10 BIG TEN
Got all 4 assembled and noticed made in Taiwan. Marked them so I don't get them mixed up between pass and drivers sides. Lol
Do you see a difference between the two? Other than dirty.
The adjuster tabs?
78C10BigTen
pennsylvannia
C10 BIG TEN
Welp, I know the speedo works.... Took my old girl down hwy 85, speedo pegged all the way to the trip switch down the highway.
45 min long drive to go Texas Steakhouse for a 16oz serlion, salad, and fried pickles!
Got into a fun little skuttle with a camaro.
We kept playing "tag"
Then he eventually stomped it down and left me o_O
We all went to longhorn steakhouse today and i had the same thing. Sirloin, salad, fried pickles, mac n cheese and frosty yuengling.
Wow, new tractor, new engine stand, new engine.
Christmas in August
I wish lol. Shop and tractor is my buddy’s. Engine and stand, yes [emoji23]
seanhatesregister
