MadOgre
NA
NA
NA
NA
NA
Installed 1/2" pex on my door striker pins last night :)
The factory one has a larger ID then the door pin so its fairly loose and able to rotate on the pin. My OCD would not allow me to use the pex with a slit down the side lol
The 1/2" pex ID is smaller than the pin.
I removed the pin. Then I cut a piece of pex to length and then soaked it in a cup of boiling water. I used olive oil to lubricate the pin (I tried with out any lube and then with dish soap but the olive oil worked 100 times better). I also filed off the sharp edge where the pex needs to slide over it and then chamfered the inside of the pex where it will meet the edge that I filed down.
Heat the pex, lube the pin and the use a hammer to get the 1/2" pex down as far as possible over the threads. Then I used the washers for the pin and a deep socket and hammer to continue to pound the pex all the way onto the pin.
It worked great on both sides.
The OD of the pex once installed on the pin is exactly the same as the factory plastic bushing. The only draw back is that it will not rotate on the pin. But heh I will just change them again when I need to. Or just retighten the pin in a different rotation to extend the wear of the pex.
Tranz Zam
MA
Ryan
LM7 5.3
I got my rust free cab and fenders on. That was quite the task with only two people and an engine hoist!
Washed up the 87
firebane
Calgary, AB
Curtis
Pulled brake booster and master cylinder... Verdict in...
BOTH are bad
Can't even get the brake booster to hole 5hg of vacuum :\
Don5
West Virginia
Don
k15
We started grinding on the underside of the bed with a drill and wirewheel. Getting it prepped to put some POR15 and topcoat on it.
Jarhead79
Mt Vernon il
Michael
Plastidipped the dash pad!
Yeah I know some people aren't fans of plastidip, but for a cheap mod and to get rid of some unsightly red painted parts, why wouldnt a $6.00 cheap alternative work right? Well I forgot the before pic, but you'll see the difference!
Jarhead79
Mt Vernon il
Michael
Eww
Jarhead79
Mt Vernon il
Michael
Better
Jarhead79
Mt Vernon il
Michael
Not too shabby for 6 bucks
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Finally took the caliper off and bent the retainer tabs on the brake pad that has been clicking around for the last 2 years.
Finally got my wheels and hubcaps put on
MadOgre
NA
NA
NA
NA
NA
Smoked some retard with a brandnew F150 right off the line. LMAO hahahaha. Brand new pickup truck and he couldn't even come close to keeping up haha
JRandle
Verden, OK
Jesse
Chevrolet Silverado
Love the whole interior man!!! Especially the oklahoma shaped piece on the door panels!!! [emoji123][emoji41][emoji106]
Sent from behind you.
quaddriver
Cook Forest PA
Ed
Chevy R2500
The big one
finally put on my 49 state 8600lb emission class cat, new magnaflow in 3 inch, new pipe (tossed out 25 year old factory stainless) and used SS band clamps, not 1 saddle anywhere.
Perfectly legal, people know its a big motor, good rumble
Jarhead79
Mt Vernon il
Michael
Smittybilt seats?
I'm wanting to go with something like these!? Are the smittybilt seats hard to make work with our trucks? Mine is a 79 and I hate my 88/98 red split bench!
Gators01
