bwh998
arkansas
brian
suburban
Started with that, so far I've made it this far:
v2500burb
Charlottesville Virginia
Jay
v2500
350ci
Should have drilled your holes first, makes it easier on the body work because it might crack the bondo when you drill it then you have to fill the holes
You were 100% correct
I will be redoing the project
DAMN!!!
Any suggestions on how to do what I'm trying accomplish???
silverscottsk10
trafalgar indiana
mike
I actually drilled my holes before even cutting them to size and welding them in, hammered them flat on an anvil, then marked where to cut, barely a overhang so there is some give with welding, then bondo, sand, prime, paint.
I'll be home this weekend and gives me a reason to finish up the three I got
I'll write a thread on it, hopefully I can sell them once I'm done
silverscottsk10
trafalgar indiana
mike
bought the paint needed to paint my steelies. One step closer to getting them mounted on the burb :)
MadOgre
NA
NA
NA
NA
NA
Did my pre winter tune up: Plugs, Cap & Rotor, Oil change and spray down the carb.
I have put off the cap & rotor for way too long so I finally decided to replace them. I found that there was a slight oily residue all over the electronics, reluctor and springs. So I used Carb cleaner and sprayed it all down a couple of times. each time blowing it all out with the compressor. after 4 times it looked pretty good. So then I carried on with the tune up. Had to reinstall the coil twice because the first time I forgot to install the ground strap in the new cap :whymewhyme: lol I wasn't all that amused at the time though lol.
But holy crap she runs so much better! :) Not sure if it was from actually cleaning the distributor or from having a new cap & rotor? maybe its a bit of both. New plugs always help too.
Not even kidding I bet I have at least a 20% increase in power. Its funny cause I was thinking about swapping out Distributors cause I was starting to think that the Ignition Module was starting to fail. I still may swap it if that oily residue returns :Insane:
Anyways she runs way better and I am glad I finally got around to tuning it up.
Replaced power steering pump
Not a bad job, but always seems to be one of the greasiest, lol.
It's a LONG story but that thing fought me due to the new pumps I bought being bad out the box. It's been a long week and yes a greasy one (giggity) :party36:
I've had my fill of power steering pumps for a while. LOL
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Bummer! It really seems like the power steering pumps are hit or miss (mostly miss). I must've been lucky with mine, my initial replacement was good and still going strong 2 years later. Swapping the pulley is a bit of a pain though.
Can an under hood reel light from a gmt400 for my 87 today. Also got some paint that is the same color as my bottom two tone. My steelies will be painted and ready to rock in the next day or two
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
Finally figured out the pulling to the right when braking! Only took 5000miles to get around to it. Went out to just rotate tires and decided to adjust my drums.......drivers side was frozen. Some heat and lube (silglyde) and a few good stops going backwards and my truck stops straight now! Gonna have to relearn how to drive it because I am so used to pressing the brake and turning the wheel left...
Sent from my Nexus 6 using Tapatalk
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Finally finished all of the bodywork and primer...off to paint in two days...will post pics when its finished in two weeks.:party36:
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
My truck rolled out of my garage for the first time since March. Completely rebuilt/regeared front axle, new timing chain and cover, new rear main seal.
Wheels finally ready to have the tires mounted on them
GorillaHumper
