foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Installed the factory TBI air snorkel, and a new pre-heater hose for the intake Thermac.
chevydude
arizona
hunt
k20
Just started to grind of the rear spring hangers to run a shackle flip and 56 inch leaf springs. Man This is going to take forever lol. I am using the front hangers of 4wd trucks instead of buying the ord shackle flip.
Then i am going to rhino line my 4x4 flatbed.
:pics-stfu:
:popcorn:
8T6K5
AZ
L98 350 TPI
Here ya' go 89......
Tore my 56'ers apart and removed the bushings...... 33 year old springs = PITA...
Tomorrow: wire wheel :gunner:
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Been there, done that. My wire wheel was super dull, so it took FOREVER...
But it was worth it.
The end result:
8T6K5
AZ
L98 350 TPI
Looks good, Im just gonna go buy a new wheel and a dust mask.
Plan on putting ORD greasable bushings in mine......then they will sit in the garage till after the Holidays.
If you got a good drill bit, drill motor and the space to get it in there, drilling a hole thru the rivet first, then with a hammer and chisel, you can usually knock it right off with a few solid swings from a 2-3 pound short handle sledge.
chevydude
arizona
hunt
k20
That is what i am going to do with the new front hangers the other ones i just want them off and i don't care how the come off. lol
chevydude
arizona
hunt
k20
Man those springs look great can not wait to take the wire wheel to mine and clean them up. I am also thinking of buying greasable bushings.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Take the four out of the middle of the pack and thats what i added to the front of my truck to "rearch" i guess youd say and bring the front back up to a positive attitude
Uriel
Mt. Pleasant MI
Finally installed a mechanical oil pressure gauge and water temp gauge.
Plugged my heater core hoses where I thought they'd go, didn't work.
I replaced the output shaft u-joint(the one that connects to the diff yoke). I was going to put it back on the truck and have some 4WD, then I found out my dad took off the straps and flung them, and now I have to get new ones. So I went to the parts store to get some, and they look like a cheap piece of flat stamped steel. Is that all they are? It didn't look very strong.
Installed my tach too. Wrong. But at least it's in there. I gotta hook up power to the tach, oil pressure and water temp since driving around and occasionally shining the flashlight at them to see doesn't seem like something i should keep doing.
8T6K5
AZ
L98 350 TPI
Dont plan on using all 8 leaves in the rear, probably 5 at most. They are going in with an ORD shackle flip and 1" zero-rates.
My front is set, have 4" Ranchos and 1" Zero-rates up front.
F/R will have 5" suspension then Ill add 1" ORD body lift.
With the weight of the K5, you probably should keep at least 6 of the leaves. I personally would keep all 8 of them. I left all 8 in the back of my Burb, they still flex great and ride like the stock 5-leaf 52's.
8T6K5
AZ
L98 350 TPI
Dully noted. Guess it will be trial and error, but Ill start with 6 and flip the overload.
Also looking into full-length teflon inserts.....???
Troyport
