Green79Scottsdale
G.R. - MI
Bob
Been driving mine a lot more this year than usual. Noticed it pulling to the left, and a weird smell when I got to work several weeks ago. Wheel and hubcap were super hot. Pretty sure the front ds brake is dragging. Or a bearing is going out. Can't do much about it right now besides research possible upgrades, due to having bicep tendon re-attachment surgery.
hoagster
California
K10, 1500
5.3l
Two more pieces primered Tamco DTA primer. The 100 degree weather finally gave up for a few days. passenger fender next then the cab! Still smoothing things things up on the cab.
Poppy 87
Bloomingdale GA
R10 Silverado
I bet that the brake hose has collapsed internally. I'd replace both sides when the time comes. Good luck
Sent from my moto g power using Tapatalk
CRM
Pasco, Washington
Casey
K2500
350 CI
Hurry up and finish your truck hoagster,You have to finish my truck before Christmas.......o_O
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Got a new water pump coming to Napa tomorrow. Flushed out the radiator and block. Ready to slap that bitch on tomorrow and fit the new shroud.
hoagster
California
K10, 1500
5.3l
I'm working on it, I have 4 parent's that are 20 or more older than me both sides of the family I'm retired and I will be 62 in November. I can't do both #)D!M(T!!!
  • Like
Reactions: CRM
Green79Scottsdale
G.R. - MI
Bob
That is another very real possibility I thought of also, good call. I am looking at braided stainless lines now. The ones on it are factory original. I am definitely going to do new lines, and just check the condition of everything else. Wildwood has their D52 caliper kit that looks intriguing. But that is $453 that I would rather drop into my Monte right now.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
You don't need all that. New standard brake hoses. The original ones lasted 40 years. ( High quality standard hoses)
Poppy 87
Bloomingdale GA
R10 Silverado
Had a new home built for Ole Bessie. Only thing left on the to do list is order a 2 post lift
DanMcG
Central NY
k10 k10
Finally got a break in the weather where it wasn't raining and was also warm enough for the epoxy primer. I hope to get some filler on it and epoxy it again before the weather really turns to crap.
FireTruck1984
Michigan
Ted
1984 and 1984
Garage envy !
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Put in my nice full sweep gauge cluster only to find out that the gas gauge doesnt work.... so i put led bulbs in the other gauges i took out and put it back together.
EDIT: mini square. Not to confuse you all
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
that. is. the. ****! Well done my friend!
thatgermanguy
