- May 18, 2020
- Auburn, Washington
- Todd
- K20, C10
^Lets see the rest of that truck. It looks clean!
Removed Cab, now I can see what I missed while on my creeper....
I finally got tired of my blower motor making noise after about a year of constant noise, I went to the parts store and got the new blower motor for about 22.00 dollars , I don't know why I kept waiting , for anyone doing this it's as easy as changing your oil and a level 1 project anyone can do.
Just remove your 6 screws holding the motor and unplug the power wire and remove the unit,
Set on your bench take off the plastic fan assembly by removing the nut and take off with a screwdriver or your hands, clean and reinstall on your new motor ,then just install in the same position it was before ,replace screws and power plug, just be careful to not overtighten the small screws and you can use a nut driver for most of it.
lower screws are a bitch to get at though
Nice find Curt can I join, I can use some extra parts
\I got pulled over today for no front license plate ,with my winch mounted in the bumper it's hard to have a plate in the normal spot so I made a quick fix today to get me by ,when I get around to it I am going to make a fold down bracket that I can mount , then if I want to use the winch I just pull the license plate down and connect it , so until I can get that done I just drilled and tapped in the bumper and took some hollow tubing , cut some 1" shims for behind the license plate and enough to clear the winch and bolted my plate on , now the local police who don't have anything to do can't harass me now.
