TubeTruck
East TN
Denis
Suburban K10
LQ9
Totally screwed over by my Suburban. Lol
Gonna heat it and try to weld it up to get me by.
What combo?
73c20jim
Tombstone, AZ
Exhaust leak on passenger side. Three nuts for flange triangle surprisingly easy to remove.
Flange on exhaust pipe is rotted off. Heat riser butterfly is gone.
Autozone rents for free exhaust tools. I need a straight flange pipe about 8" long. Shouls be easy to replace.
Should I replace heat riser or get a bypass???
By the way I live in southern Arizona.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
That sucks! Should weld up okay though.
Poppy 87
Bloomingdale GA
R10 Silverado
Wouldn't worry about heat riser in AZ. They operated marginal at best when factory new!
Sent from my XT1254 using Tapatalk
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Bypass that ********- can't freeze up on you if it ain't there !:waytogo:
Plus, the AZ thing.
80BrownK10
Greenwood, SC
Nate
Out of curiosity, I stuck my hand under the carpet and she was a little wet under there. Giggity Pulled it all up and Sound Deadened and closed cell foamed it. Found the water leak in the cowling where the old seam sealer had shrunk and cracked. Put new seam sealer down and also replaced the kick panel vent A/C version. Got the interior back inside today
I wish someone had found mine before the floor board Rust and the side rot out like they do. I fixed the leak and globbed goop (Bondo...) and whatever I could in the rust holes like those of us who don't weld in patch panels do. It works for what it is. Truck was never meant to be a show truck anyway.
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
My welding is crap and my welder is even bigger crap. Flux core welder. Flame me. LOL
Just praying its gonna hold. The arc was like a Mexican jumping bean. Maybe a tad better than Stevie Wonder(@78C10BigTen)(@Vbb199). LOL
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Some qualiy booger welds there man!!! Lol please update on the status after you put it back together
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I bet my welding sucks more brother. Lol
Hope it holds for you
80BrownK10
Greenwood, SC
Nate
put the rebuilt wing window assy back in. THAT was a mutha. One down one to go.
Bed liner was not color matched like I wanted but it’ll do for now.
I redid mine as well. The rivets didn't come back together like I wanted. One side I took the hinge apart and the other side I left it together. Neither side is perfect but works. You really need one of those C clamp things for the hinge rivets. I did mine in the vice and it looks ok and seems as good as it should be.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Trying to remove the worn out tint. What a pain in the crapper that is. Got 2 windows and both vents done. Went through 6-7 razor blades and took me an hour.
That's a shitton of razor blades, work smarter not harder.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I say give him a break...
My flux looks like bird poo too.. Ya just can't make a quality flux weld really lol
Sent from my SM-G965U using Tapatalk
wkeithh
