caliphatman8123
Bakersfield, Ca
Sam
v1500 suburban
tbi 350
That's nice work
Sent from my SAMSUNG-SGH-I717 using Xparent Blue Tapatalk 2
8T6K5
AZ
L98 350 TPI
Where can that bracket be found? Caprice cop car or something?
There's alot of uncertainty exactly where the bracket comes from. Some say Police Package Caprices...but the CS-144 doesnt fit it?
Others say some Caddy's and other GM models that optioned for the 120A upgrade...
I got mine here: http://www.gmnosparts.us/10118722.htm I could be wrong but the bracket isnt needed for every application.
Heavyleft did a write up in here, cant find link, doing the same thing w/o the bracket.
As far as the harness, from everything Ive read...if you have a gauge you need the resistor, no gauge-idoit light only, no resistor. NAPA has PN's for both parts, however there was a huge shipment of mispackaged harnesses....per NAPA employee...thats why anybody who goes to NAPA is rolling the dice.
I got mine off eBay...same one in this thread http://www.gmsquarebody.com/forum/showthread.php?t=2670&highlight=CS144
Link to the instructions Im following...specific to a TPI 350: http://sethirdgen.org/cs144.htm
Pic from the backside:
Belt is on the shelf, harness to go from CS130-CS144 enroute, just trying to find the time to dig into it.
I've put the bigger alt on the older TPI's with the individual belts, which is one reason I liked that setup. I never knew a conversion bracket was available for the '88+ serp setup.
8T6K5
AZ
L98 350 TPI
There are options to buy a new CS130 140A (even 200A+) or have the OE re-wound....and make it a simple swap...
Between the bracket, the alt and belt (which needed to be replaced anyway), Im into this for < $100.... much cheaper and I get to be a little more hands on which is always a good thing....imho.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
I put a t-stat in mine yesterday. Went with a 180 Ultrastat from OReilly's.
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
i slung a little mud and snow taking out the garbage today with my truck tire chains FTW
8T6K5
AZ
L98 350 TPI
Removed hitch, pulled bumper, dropped tank, took off rear springs:
Will start grinding off rivits tomorrow....
Also pulled alt, plugs, wires, coil, cap, throttle body, T'stat.....working towards pulling injectors.
Pics of the 105A vs. 140A
Besides being rich, what are my plugs telling me? #6cyl is very dark...
Green79Scottsdale
G.R. - MI
Bob
They're saying you're running terrible plugs for a GM.
Couldn't agree more!
Get proper plugs with a single strap and gap them correctly. The gaps on those looked up f#cked up. If that was a real question about what they are telling you, do a leak down test. #6 looks like possible ring seal issues.
Painting your bumper black while it off perhaps?!
I only run AC Delco in my GMs and for good reason.
8T6K5
AZ
L98 350 TPI
Made a little more progress today, got the plenum and runners off...
Started cleaning them...
Need to replace a few hose that were ethnically re-engineered...
Few comparison shots of the 6" ORD shackles and the OE:
And the 1 Ton springs w/Zero-rates vs Rancho 2.5" ......surprisingly they appear to the the same height...
Just waiting on UPS man for my ORD brackest and 2 more boxes from Rock Auto :)
Yeah, no kidding. Seven of the plugs felt like being a nice guy, but plug #6 did the normal Bosch thing and just said "fock off, I don't wanna".
8T6K5
AZ
L98 350 TPI
Seven of the plugs felt like being a nice guy, butt plug #6 did the normal Bosch thing .
Fixxed.
Needless to say they wont be going back in.
thatgermanguy
