82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Got the new ceramic connectors installed on the top two lights and wired up the halo lights to run off the running or parking lights.
Had to put the old sealed beam back because the lights wouldn't work with it unhooked. As long as I can get it inspected I'll figure out the bottom two later.
Auburn, Washington
I decided it was time for some cleaning. Used some 150gt sandpaper and sanded the top part of the door panels where it was really faded, and softened some of the scratches, then i magic sponged some of the stains off, and finshed them with some special orange, orange oil furniture cleaner/polish. Looks great, and smells great.
Also took my old faded, stained, shrunken dash mat off, and said screw it, looks better without. Used some goo-gone to take the velcro pads off, and i washed and polished the whole dash. Couple coats of that special orange. Looks great i think. Im just going to leave it that way now.
That looks way better! And the fact it cracked very straight and almost symmetrical is even better
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
Had to show the Neighbor boy what the chevy wheel was going on today when He .came down to help Me with some stuff.. Good kid but drives a F O O D,, Maybe I can help him,, I drove F O R D S too befor I grew up,, Will have to share that with Him,, Maybe it would help..
WFarm
Central Virginia
K5 Blazer
Beautiful evening for a Cruise In! Dusted the truck off after a day of Flea Markets and hauling horse feed and bedding and headed to a local event. Lots of really nice cars but my Square was the best! (OK, I may be a tad partial, lol)
Cleaned up and painted my steering linkage today...
82sbshortbed
Fuckemall!!
SE Texas
Doug
Very clean! Looks great!
mxer147
Colorado
Jack
k20
Also took the gauge cluster apart to fix 2 burnt bulbs and bad gauge, and while i was in there, took it out and apart, and cleaned everything.
Reassembled, polished the lenses, cleaned the bezel. Also cleaned and oiled the wheel, column, and shift knob.
While i was in there, i installed my new, foil tape lined, gauge light reflector. Hopefully that'll make the gauges brighter.
Looking a little better in there...
Gauges look awesome! How did you clean the gauge faces?
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Thank you.
Compressed air.
I charged the tank to full, then cranked the regulator open all the way, so had 150psi at a blast, and i used a blaster tip with a very small hole. They were mainly dusty. I wasnt going to risk going in there with a rag and smudging everything.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Found and fixed two substantial vacuum leaks when replacing vacuum hoses. It actually made things worse, but not right away. I think the extra vacuum may have caused the already compromised vacuum advance can to fail. It wouldn't hold vacuum when pumped up with the vacuum pump, and before the test drive the engine ran way smoother than it has in a very long time. A new 1852 can will be in today.
tater dog
tater
k30
Guess these pointers on the gear selectors break off easy . Used a pen top to replace an otherwise working part .
CoggedBelt75
Oklahoma
Joe
Gotta do whatcha gotta do.
