Redfish
Prairieville, LA
Andrew
V1500
Did a quick repaint of the grill and headlight bezels just to spice it up a bit.
Only did the silver, to make everything match, didnt do the black.
@Powerhouse Ranch recognize the headlight bezels? Those are the ones you sent me. Was orgilally going to use them on my 85, but the ones on this truck were all broken from the last hailstorm, so I decided to use them on this.
Those headlight bezels are about $17 through LMC. I installed a set on my '87 because the originals were so badly beat up. Actually ordered a replacement grill through LMC at the same time but had to order all new plastic grommets and got new screws as well.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Wow, really? That's surprising. That seems cheap. Well I got these for free plus 12$ shipping thanks to Mr Luke, and they're in great condition, so no worries. But I'll keep that in mind. How much was a new grill? The mounting tabs on mine are a bit busted, wouldn't mind having a new one.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
atta boy Ayden. This rig has come a hell of a long way. These are accomplishments pretty dream of doing/take years to do. Keep up the great work man! (Excellent bezels!!!)
Redfish
Prairieville, LA
Andrew
V1500
Ayden, according to LMC a new grille (You have to put that E at the end of grill) for a 1985-87 GMC is $89.95. Part #38-3859 It will NOT include the GMC emblem (mine is 3 separate letters).
The headlight bezels give you 3 options:
Standard for $10.95 each.
Premium for $17.95 each.
All Chrome for $69.95 for the pair.
I was going to just paint mine but they were beat up pretty badly. Yours look great in the pic though.
Was doing some basic maintenance on the '79 crew cab. Basic stuff like greasing everything, checking u-bolt torque, etc and I was going to rotate the tires too. The fronts are rotted and worn poorly, figured I'd rotate them to the inside rears. To make life easier, removed the front wheels and installed my hummer wheels and tires that I had as spares, so I could just have one end of the truck jacked up at a time.
Well dang, I think I like it, lol. The wider fronts give it a beefy look that I dig. I may just leave it like that for a while. I'll remove the rear simulators and paint the rims to match the front. Or I'll paint the fronts to mach the rear. Not sure yet.
Nevermind the bird and bat poop, it's been in the barn for a few months.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Not bad!
Doppleganger
OH-MI: Just like it sounds
I was running the EFI bug catcher when, for whatever reason, I took it off I was amazed at the amount of oily film that made it into the intake. I used a simple water separator for an air compressor. Took the guts out or the top & sealed the bottom petcock. Put in between the PCV & bottom of throttle body. Painted it black to blend in with the firewall. Does a great job of catching all the nasty stuff that used to go in. Now it’s hooked to the bottom of the carb plate. I just unscrew it to dump. Eventually I plan to run braided line but I’m frugal with some things...ie, cheap.
The caps are Billet Specialties. PCV in one & a washable filter in the other.
So you only tapped the catch can off of one side? Thats what is bugging me....if there is a way to plumb it off of both sides. I made mine a few years ago - is (iirc) 1-1/2 to 2 qts. Has a ball valve in the bottom, copper chore boys as a filter and is sized to fit in a charcoal canister bracket.
Camar068
Kentucky
10 yrs Air Force
lol.....sorry but those pics aren't "cheap"
CoggedBelt75
Oklahoma
Joe
Yeah, one side has the hose from PCV going in. Since it comes in from the sides, heavy deposits of oil that's sucked in drop to the bottom. Fumes pass thru the other side into the intake to be burned off. Simple yet effective. I empty out as needed.
Ya got me on that one:cool:
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Thank you. And thanks again for the bezels.
Hows your Jimmy?
Turbo4whl
Downingtown, PA
Wayne
Jimmy
You only have one PCV valve and that vents the whole engine. The other valve cover needs a breather to let air in. I like your catch can, nicely done!
The only "V" engine that I know of that had two PCV valves was the V6 GMC in the 1960's. One screwed into each head under the valve covers. They were plumbed to the intake runners on each head. The breather was the oil fill cap. The oil fill went right to the engine valley.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
Hows your Jimmy?
sitting around awaiting body work; my worst forte. Been really busy lately, and can't find anyone to give me a hand/show me the ways.
Auburn, Washington
Invested a solid 4-5 hours in 100 eg weather getting the door handles back on the truck....So simple yet so difficult apparently, lol.
And couldn't put the door locks back in as one of them decided to not work any more. IDK how a working door lock got jammed up sitting in a box for a year?
1979 c20
Rat
Won't some penetrating oil loosen it up? You would be surprised what can develop surface rust and how little it takes to gum up the works.
Auburn, Washington
Or $16 for a pair of argent dual headlight bezels. I put more time into sanding and repainting mine than it was worth, should have just bought new...
Alfonso
