What fluid and capacity in 85 Chevy k10 manual 4-speed ?
Redfish
Prairieville, LA
Andrew
V1500
I’ll try to get some better pics of transmission. I can’t argue they are pretty bad pics.
The shift knob pic tells us all we need to know. That is the SM465. It takes 80W-90W Gear Oil. You can google "SM465 Fluid Type" and "SM465 Capacity" if you like.
I did throw in a quart of expensive synthetic when I did mine...just because.
Auburn, Washington
These old trucks get the special treatment now…
That was like some geritol for its old bones! Haha
sqhead
Mexico
Roller
custom k10
Thank you all for the good info. Greatly appreciate the knowledge.
sqhead
Mexico
Roller
custom k10
Which would you all prefer amsoil severe gear or or redline?
85K304SPD
Las Cruces, NM
Richard
SM465 stands for "Syncro-mesh". It takes Syncro-mesh gear oil. I think Pennzoil makes some. You have to be careful about putting modern stuff in there, it will eat up the brass syncros.
sqhead
Mexico
Roller
custom k10
That’s good to know about the brass. I keep looking to see if I find the pennzoil
Thanks
Daron58
Ponchatoula La.
Daron
250 I6
I just replaced the shift forks and put a kitin the top cover and I put exactly 4 quarts in mine, make sure it’s the 80-90wt GL-4 from what I’ve read and heard that the GL-4 is better because of the brass synchronizers in the internal parts, just my 2 cents worth
  • Like
Reactions: WFO
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Debatable. I always was told "sm" stands for "Saginaw Muncie". Some even say "saginaw michigan".
As far as lube, all I've heard is gl4 80-90w.
82jimmy
