Weird Headlight Problem
DougC10
Doug
C10 Silverado 1500
Welp, that went sideways. Hope you get it fixed. You say non productive, when you got solid advice. I'm out.
Thank you. I feel the advice was well intentioned but there is a missing link to this.
I will track it down
Auburn, Washington
If you have 12v at each socket on the right pin and the same good ground on the right pin at each socket then your headlights work.
There’s nothing else between the socket and the bulb.
But you’ve checked that it appears. Good luck
fjordanasi
