vinyl floor replacement help/opinions wanted
WebMonkey
Missouri Ozarks
my 85 k20 has a vinyl floor in it, it needs replacing.
it looks to have a backing or padding.
i have an LMC catalog but i'm not sure what they offer is what i have/want.
has anyone replaced a factory vinyl floor with aftermarket?
if so, what did you use and where did you get it?
i'm 99% set on vinyl rather than put in carpet.
i'm waffling over a 'dynamat' layer since i don't know how well a vinyl floor would fit on top of that.
thanks for your time.
SDJunkMan
Black Hills of South Dakota
Jeff
I too want to go with vinyl, as my truck is used for plowing snow and gets a lot of snow tracked in. I was interested in the 1/8 MIP polyvinyl mat, but would also like to hear from someone that has actually used one. The factory rubber mats in my truck wore out a long time ago.
Keith Seymore
Motor City
Keith Seymore
4.3L
I used a floor mat from vendor Capt Kaos (on the 67-72 board). It was thick and molded to fit my high hump configuration.
I ordered one originally from somewhere else (I'm afraid I don't recall where) and it was awful. Thin, and not molded. I sent it back and got the one mentioned from Capt Kaos.
I think this is his website: http://www.73-87chevytrucks.com/
K
B.K. Cunningham
Spokane, Washington
Bryan
25 Hundred
if you have trouble finding a good one, try rockauto. I just got carpet from there, its from ACC, good stuff and a bit cheaper then most places.
Holl
Rich
suburban
I have put in 3. One in a 60's GMC pickup that turned out real well. 2 in squarebody suburbans. They didn't turn out as well. The MIP didn't seem molded as well as the pickup...but they do the job.
Mine were from "action carpet" or similar. I bet they are all made in the same plant.
there are several youtube videos on installation. Make sure you do it on as hot a day as possible. The mats are oversized and real hard to work with when cold. Lay them in the sun till they are 90 degrees or better. Have a sharp razor knife to trim. A 1 inch hole saw works well to cut anchor bolt holes. Run it in reverse in your drill.
my kits came with backing, similar to jute. You can add carpet backing if you want more padding.
The88
Mhmm
South Louisiana
ThatGuy
I also put a molded in my k5 and fit great. It had the jut backing installed. Well worth the money especially when it got dirty.
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
I put an NOS ( Military surplus) rubber floor mat in the '76 K25, fits nice but needs something like jute underneath.
WebMonkey
Missouri Ozarks
thanks all.
this has alleviated some of my hesitance with replacing the flooring.
i don't think i want to spend the extra on the 'dynamat' though.
it cost as much as the flooring!
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
i would spring for the dynamat, heat and sound reduction just makes the whole driving experience better. Icon and all of the pro builders use it. quality is remembered long after the price is forgotten.
roundhouse
atlanta ga
justin
77,78,79,80 ?
Dyna Mat (we used Fat Mat brand )
is totally worth the money And install time
WebMonkey
Missouri Ozarks
qsl, i found a more affordable 'brand' than the lmc dynamat style product.
i will definitely be using some form of dynamat to lay the jute/vinyl over.
thanks!
MikeB
Forgot where I bought my vinyl floor cover, but it covers the entire floor with jute padding running back to the front of the seats. I had to trim it a lot at the front, but better that than not enough material. Recently, I actually replaced the jute padding with insulation (The Insulator) on top of sound deadening material (Noico). The cab is very quiet now and I haven't put sound deadening on the doors yet.
unimogguy
