Update on my Ignition Module failure!
Gpaw44
Alex
My 2 year old Accel Ign. mod failed after 2years and 2 months. I bought a new one and after about 3 miles my truck died and I had to have it pulled home. So back down to the O"Reilly Auto Parts I went to have them check the Ign. Mod. It showed to be bad and since I had a one year warranty so he grabbed a new one of the same brand off the self. I aske him if he would check to see if it was good. It also failed the test the test. Two of the same brand failed making it 3 failed Ign Modules.
Talking with my auto mechanic friend he suggested rather than piecing an old distributor with new parts why not buy a new one. So on Friday I order a new Excell Dist. from Summit and it came in on Sat and was in the truck Sunday afternoon. Drove it around for about 15 miutes before the truck died and to be pulled home again. Now the toal Ign, Mods. is five.
This morning I loaded the truck up and took to a person who makes a liveing diagnosing electrical problems in vehicles. He showed me that there was close to 13 voltes gong into the Dist. but a spark so dim it would not make the truck run. In other words the voltage was going in but not coming out! He told me this new Dist. was bad and that I should warranty it. I have another one coming in in two days.
We are not getting quality Ignition Modules!
Not wanting to convert to an LS swap but I may have to be able to drive my 86 GMC.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
I had a USA made Borg Warner HEI module crap out in a month or so. The replacement AC Delco is still going so it's the only replacement I would recommend. Good luck!
I only recommend genuine gm,delco gold or NAPA premium. To the best of my knowledge those are the only modules that hold true to the original design and vary dwell or vary dwell in the original fashion based on engine rpm. By using cheaper components they can make more profit,and or offer a cheaper part. But if the cheaper componentsbwon't match the O.E. spec for dwell,what else won't they match?
77Dmax
vt
Joe
Put a points distributor in it. That will run forever. You'll need to adjust them once in awhile though.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Will an msd module work? I've only had one that would lose spark after sitting over night but if you tapped on the distributor it would fire up. Replaced the module it was fine ever since.
Only "bad" msd module I've had.
Gpaw44
Alex
Thanks for the responces. I just check and on Amazon and a genuine AC Delco Distributor sells for 440.00 and is made in Taiwan. Where are you buying an AC Delco?
77Dmax
vt
Joe
People think I'm nuts for this but a solid source for real GM parts is the boneyard. I have pulled modules from parts cars and gotten a long life from them.
I don't buy distributors I use genuine GM,AC Delco gold,or NAPA premium modules. I reuse/ rebuild,find new old stock, as much as possible,new parts as a general rule in my opinion,are not as good as the parts the cars were made with new.And a lot of new parts not suitable to use at all. Also as insurance I'd add a ground from the engine block to the battery. Or block to body or frame,but only if you are positive the body and frame have a good ground to the battery. Bad grounds kill modules,failing coils kill modules,too much sparkplug gap kills modules. Also check voltage at the cap when you get 8t running,make sure you are getting battery voltage nit a big volt drop or a big spike from a bad voltage regulator.
Lancew
