Ignition Switch (Tilt Column)
Robert Bare
MT
Robert
k20
In reality, you are asking the switch to do something it was never designed to do. The full tilt up was only to get in and out of the vehicle. Later ones were better about this. Picked up a tilt column for plow truck from nephew, was a mess, rebuilt it. So I checked, yes will work all the way up, but is stiff, of course. Now need some snow to melt so I can install.
Anyway, when going through these, the gear set and slider cam are cheap to replace. The biggest thing, don't just slap some grease/or spray. Disassemble clean and remove all that hard as a rock grease.Especially on the ignition switch slider rod and actuator, even remove the tension spring and clean.Then lube. Use Deoxit on/in ignition switch, it is safe and leaves a lubricant behind.
Steelbuddha
Central North Carolina
Jonathan
K20 (dump bed)
On a similar note without hijacking the OPs thread I have a question. My manual trans, non-tilt (not that it matters) has become quite tight to turn the key when starting. IIRC doesn't the cylinder rotate and a rod pushes the actual ignition switch located lower on the column? I'm just wondering which part would cause the resistance.
The rack and sector gear assembly is an extremely rinky-dink arrangement. Plastic sector gear engaged with a pot metal rack. Lots of opportunities for binding. What could possibly go wrong? The stupid parts cost about $8, but you have to take the whole steering column apart to replace them.
Bubbie
