Turning off weird
horchata81k10
caldwell
Chad
been like that since i’ve bought it but i’ve replaced the fuel pump and fuel filter in the carb
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
Can't see the first video but if it is running on when you shut it off probably the timing is off.
SquareRoot
That's what they do when they die.
Sh!t can it, put an L.S. in it. and a holley!!!
What's your idle speed,sounds really high. You need to look for vacuum leaks. Then you need to get your idle speed down. After that you need to set your timing and then set idle mixture and set the idle speed.
Rusty Nail
Rusty
350sbc
It's not fuel , it's spark. The ignition timing is prolly advanced is all and It could be something as simple as a vacuum leak. Do you have any skills?
You know like, truck fixing skills?
Rusty Nail
Rusty
350sbc
OnCue convenience store has yummy HORCHATA in their wide selection of fountain drinks.
You can always tell the quality of the store depending on the mixture of their HORCHATA.
For those that don't know what it os : it tastes like the milk left in a cereal bowl after having "Cinnamon Toast Crunch". It's uber bomb ish.
Pinche horchata - check it out!
armchair
