- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
And that's all there is to that folks. Slow and Tedious !!! I now have new threads. Towel and gasket is now removed. All shavings were vacuumed off the towel and gasket. And I also carefully removed the towel and gasket as if it did have shavings on them, just in case I may have missed some with the vac. So back to where I left off and ready to install the pump AGAIN !!!
As previously discussed and pictured. The pump is now installed, torqed to spec, input shaft end clearance checked again, input spin test in both directions and all is well to this point.
The transmission is now taken out of the hole on the table, and laid on its back with vavle body area facing up. Its now time to install the vavle body and all the externals and get this thing finished finally. Fingers crossed, hoping to not have any more unforeseen incidents.
