Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
Maybe I’m extra confused what you meant. I was saying the crossmember IS under the frame...Don't know if I worded it wrong but I meant the crossmember is always on the bottom of the frame. I was trying to explain the order, like exactly how it looks in the OP's original pic.
This is true, I've personally never seen a truck with crossmember mounted on top of the bottom frame rail, so I can't speak on that, but I believe you. I just didn't think that would be an issue as it would be less than a 1/2 inch difference.
