- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
When I put my hub back on(D44) incorrectly last year, it wouldnt fully engage the teeth because i bent the snout on the spindle a wee bit so the cam couldnt slide into the sprocket thing unassisted but it would disengage. so i had an annoying click peridoically at low speeds( I dont drive on road) and found out in the mud i had 2wd only. The indicator on the hub didnt line up with FREE and LOCK and I just assumed i put the cap on wrong
but if you havent touched it, it shouldnt be that. but always a thing to consider. i would jack up front, put both in free, and give her a spin, it shouldnt bind or have the shaft move.
then put in lock, and give her a spin, the shaft should spin.
then if you are still good, like suggested, check your wheel bearings for play which i think you said is good, but its in the air why not. then brakes would be next logical contender for me
