Throttle cable way too long
Mango
JacksonWyoming
Gil
Is 22" cable OEM Length?
Yes. The overall length 22". The housing about 11"
My 75k 350 quadrajet,stone stock. Firewall to throttle cable bracket distance is about 8.5 inches cable housing right about 10 or 11" which gives a nice little bend. Some people don't realize that bend is important. The housing and cable should not be a straight shot. I have read but do not know personally a K cable and housing is 2" shorter
Mango
JacksonWyoming
Gil
Replaced throttle cable with A Holley Cable, it still sticks cable is very aggressive and rube the housing neat the fire wall, Greased it heavily, still rubs the intake cable housing, I think it needs to be lined up perfectly, Will need assistance for this WAPITA! Still looking foe OEM Cable ?
The cable housing I removed was 20" long New one Like 12"
Lets see your return spring. Original spring was 2 springs and pretty stout.
Mango
JacksonWyoming
Gil
Return Coil Spring you can see it bottom left of photo I will get a Close up After I recover from the food coma !
If you're talking about the wound up spring on the throttle shaft,that's not enough,not even close. This is pretty much standard issue.
Mango
JacksonWyoming
Gil
TBI did not have that on when i Purchased it? the old throttle cable worked fine. until the bottom attachment to the peddle broke
My throttle cable appears too long in my application but im using the bracket for a 2 barrel with th350 kickdown (2jet 2 barrel) on a edelbrock square bore manifold with a edelbrock 1406. So I would assume a majority of the issue is the bracket.
Mango
JacksonWyoming
Gil
This is where its sticking, cable intake from peddle stainless Steel cable on Aluminum Intake greased the ^%$@ out of it no help. Notice how aggresive the cable is
Mango
JacksonWyoming
Gil
No More sticking throttle cable!! Ordered one from ebay OEM used $ 24.00 with shipping showed uo and the outer housing was full of cracks wrapped it with electrical tape installed it and no more sticking works great! I found a few more on ebay and now I have three for spares OEM is what you need
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Used the Mr gasket 5657 and now it works great! You can cut it to fit. No more big loop to bind up.
2manysquares2care
