This makes 0 sense to me! Heater hose route
jimmy78
bc
matt
jimmy
5.7l
Can someone shed some light on this monstrosity of a heater hose routing.
Rad to heater core with tee to intake manifold
Heater core to water pump
This seems janky to say the least.
mtbadbob
Montana
Bob
V20
Not sure what the line to rad is for, maybe it had a secondary return line for whatever reason.
jimmy78
bc
matt
jimmy
5.7l
I’m thinking capping the intake port and flowing rad in pump out or vice versa.
I’m not super mechanically inclined so the help I get on here is amazing and greatly appreciated
has to do with automatic transmissions
If your lines are not leaking, you are at worst going to causew noise in your heater hoses and core and wear it out faster and wear our your water pump and potentialyl cavitate fluid.
At best it would work fine. I would leave it
jimmy78
bc
matt
jimmy
5.7l
It’s leaking at the manifold lol also my ocd is triggered
its to heat up the trans in cold weather. and the other stuff i said
then the hose looks sus i would advise replace that length of hose and the other one. you need both sizes of hose, then just get some spring style clamkps and they will be good for years
Your hoses are also too short for factory routing. factory they clip to the fender.
jimmy78
bc
matt
jimmy
5.7l
I will swap the hoses out. From the second image it looks like auto trans should be rad to core core to manifold. Eliminating the water pump connection. I feel this would block the heater core off till the thermostat opens though
mtbadbob
Montana
Bob
V20
So, is there supposed to be a third nipple from the core for that line?
The diagram is showing the water pump connection its just a little far over.
see the water pump in the pic and the intake
The split of the hose, done here, is factory, you can reuse the pipe you have to T into the line to the water pump.
jimmy78
bc
matt
jimmy
5.7l
I see it now. I thought it was an either or diagram. Autos going to the rad and manual s going to the water pump
oh lol. And If you WANT to improve the setup you could get a Y fittting instead of a T but thats splitting hairs lol..
tweeter68
