fast 99
- Dec 31, 2021
- Spokane, Washington
- Brian
- K20
Wasn't criticizing the employees. If a part isn't manufactured within adjustability not much in the way of options. Back then close was good enough. Really don't know how they could be assembled as fast as they were given the variations.Here's how we did it:
"Quote=Keith Seymore
What we used to do for fender shims is tape a packet together, like 3 shims, and we would run those all day whether the truck we were currently building needed it or not.
Eventually the final repair supervisor would call back and say something encouraging, like "SEYMORE!! YOU IDIOT!! WTH ARE YOU THINKING?!?! ALL THESE FENDERS ARE RUNNING HIGH!! ARE YOU EVEN LOOKING AT THESE TRUCKS?!? TAKE A SHIM OUT BEFORE I COME BACK THERE AND SHOW YOU HOW TO DO THIS!!" I can just imagine the spittle flying into the phone mouthpiece.
So we would start running a new shim pack, like 2 shims, until he called again with his latest observation.
Basically it was to address "macro trends". You had about 45 seconds to complete the truck in front of you and move to the next one; that's not enough time to fit and re-fit each individual truck."
Also -
"This technique would get you close on the majority of vehicles.
There was a repair station at the end of my area. There was also a short moving repair line (two, actually) at the end of final line. If they could fix them there while on the move then they would; otherwise it would be out to a stationary repair stall in "heavy repair" for the really bad ones.
I should add that some of the repairs did not consist of removing the bolt or adding/deleting shims. Often the repair consisted of bending, twisting or hammering while the line was moving."
K
Add window adjustments into the mix like hardtops. My Ranchero is a total nightmare to stop wind noise and still close the door. No way in a few seconds the line could adjust it. Quantity was job 1, quality job 2, safety job 3.
