Tbi to carb to tbi swap
I’m going for a cattle show and last year there was a swap meet going on down there so it could be going on again this year
There's the Cars & Parts swap meet a few times a year. They are a "must-go" for any car guy, especially the warm season events.
Derick C.
Auburn WA
Derick
454/700r4
All that comes on the engine. All I’ll need is the new lines. What should I tell Napa I need lines for so I get the right ones?
my 90 suburban has the AC on the passenger side, so does my 92 gmc, so just pick a newer year than yours.
87silveradok20
Ohio
Levi
Silverado k20
Well today I got the confirmation the motor finally shipped. This project should be underway somewhat soon here.
87silveradok20
Ohio
Levi
Silverado k20
I finally got the engine here. Now I have a few questions. As far as vacuum lines, this carb has two ports. I was thinking one port for the break booster then putting a T on the other one and running the heat controls, vacuum ball, and trans vacuum line (th400) off of it. Does that sound right? Am I missing any important vacuum lines? Then for the fuel system can I have the mechanical pump on the block draw through the factory tbi pump or should I take the factory pump out of the tanks and get a different sending unit?
4WDKC
Southern Florida
Kacy
Get a different sending unit... why did they reinvent the wheel and come up witha serp setup that mounts the ac so low? Thiose stock lines mentioned before wprobably wont work with that serp setup and the compressor is different also.
87silveradok20
Ohio
Levi
Silverado k20
I’m not sure. I kinda wondered the same thing. This actually has two belts so not a deep setup but way better than the stock setup. I think I’m just gonna measure how long I need and get the hoses custom made
87silveradok20
Ohio
Levi
Silverado k20
I also did some more looking and found that the carb has another vacuum port so I’m thinking that I should run for the trans and the other for the vacuum ball and hvac?
87silveradok20
Ohio
Levi
Silverado k20
Can I just buy a sending unit for an 86 and put it in my tank? I’d rather not get new tanks as I have plastic ones on my truck now.
4WDKC
Southern Florida
Kacy
yeah you can buy the 86 sending , may have to make an adapter plug ir reuse the 87 sending unit plag to mate to the harness just leave the pump wires unpined. There should be a port on the intake for the brakes to get manifold vac, freeing up the other ports for hvac/emissions/whatever. Think I see it in the pic you posted, copper/brass pl;ug in runner for cylinders 6/8
87silveradok20
Ohio
Levi
Silverado k20
Alright sweet. I’ll get two ordered then
Where did you get plastic tanks from?
silverscottsk10
trafalgar indiana
mike
Are they plastic or have the plastic protectors?
Sent from my SM-N950U using Tapatalk
87silveradok20
Ohio
Levi
Silverado k20
I’m not sure. My dad put them in about 20 years ago
87silveradok20
Ohio
Levi
Silverado k20
They are plastic. I took the protectors off
ajd89
Central Michigan
andrew
I wondered if you could still buy them ive got one i pulled off a truck but its a small tank. Never looked in to buying one but wondered why no one went to plastic tanks.
ben_swager
