tbi issues, on my 88 gmt400
Swims350
Logan WV
none
I don't think we did on this thread but I've heard it before. when I built the motor it wasn't slipped, because num. 1 tdc was right on with the balancer and tab set at zero.
Swims350
Logan WV
none
ok now I'm looking into a couple smaller cams to use in this...
one is a summit or elgin, 218 dur. 450 lift and 106 lsa.
the other same makes, 222 dur and 467 lift with 110 lsa. or cl I forget which they list it as. It's either the lobe seperation angle or the cam center line.
Also looking into when I do this getting a summit head kit, with springs, locks, seals, and then I think the retainers come in it? That way the springs match and are not old 305 springs.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
So I went ahead and tried the 5.0 injectors. I'm not gagging at stop lights with the back window open and the SES light hasn't come on once.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
I would check those numbers back on the block.
Swims350
Logan WV
none
well the 305 heads I got are 601's I guess I missed the 1, because I got 1402260 and e224 near it.
other then that no change, been pulling the monte carlo motor apart and out.
Chevy Legend
