Tail light screws 1980?
So I got complete new assemblies as mine were broken, bad, cracked, aged. I go to put them on and literally every screw is mismatched. Some square heads, some hex. etc. Does anyone know where to get a set of 18(thats how many there should be in total) screws for the tail light? There should be 8 that screw into the bed, then 8 that screw into the backing thing.
DanMcG
Central NY
k10 k10
Any Pick and Pulls near ya?
LMC has them, but they're $0.50- $1.00 each
Iirc, it's phillips screws that hold the housing to the bedside and torx screws that hold the lense to the housing. Earlier years may have been phillips for the lense too. As long as the lense screws are stainless, that's the important thing.
Dmack
Central OR
Dave
Of you could just go to a local hardware store. IIRC, they are #8x1" .
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Accurate for me
Well regardless, does anyone know? Are all 16 8x1? Does anyone know for sure? As long as I know the size I need I could go just hardware store. And unfortunately no pull part salvage yards near me. Id prefer new hardware regardless.
#8x1" sounds about right. 1.25" should work too.
chengny
Classic generally supplies good stuff. The housing screws (Phillips) are OEM but the lens screws (Torx) are repro.
https://www.classicparts.com/Taillamps/products/365/0/1/
Tail lamp Housing Mounting Screw for 1973-91 Chevy Truck
Screw used to mount the tail lamp housing to the body. 4 required per housing 8 per truck. Fits 1973-87 trucks and 1988-91 R/V series.
(1973-91) Tail lamp Lens Screw-Fleetside ea.
Sold each. Replacement for the Original GM with Torx head. 4 required per lens 8 per truck.
seanhatesregister
