Tach needle bouncing.
Matt Frediani
California (Nor-Cal)
GMC V2500 Camper Special
TBI 5.7 350
Hey folks,
I installed a tach (Tach conversion kit) in my 87 TBI 350 GMC V2500 truck. All the gauges work as they should but the tach needle bounces. At Idle its not bad but when driving the truck or giving the truck gas the needle bounces around. I grounded the tach to the firewall and was sure to scud the metal up good before I grounded it. Any ideas? I also used the hot for the ignition because the conversion kit wire had an end on it that plugged right in.
Thanks
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
EMI from the sparkplug wires or coil possibly.
I added a tach on my burb. It was fine until I added the spark controller and coil. Same symptoms you're saying.
I don't have that stuff on my truck now, tach reads fine and doesn't jump around.
Matt Frediani
TBI 5.7 350
UPDATE-
Even though the truck was running great I decided to replace the coil because it was original. As soon as I replaced the coil the Tach quit jumping. Problem solved
Dave
Suburban
I had exactly the same experience. I rebuilt my dash with a tach upgrade from LMC, and the tach would bounce when driving, but not at idle.
The old tach looks like the original, with at least 200k and 33years on the clock.
New tach and it works great!
GorillaHumper
